Activity Forums Adobe Premiere Pro Clip playback speed and file import failure
  • Clip playback speed and file import failure
    Posted by Robert Withers on June 30, 2013 at 9:17 pm
    Hi all,
I’ve just started the switch from FCP to Premiere on my Macbook Pro and am stuck early on with two issues.
File Import Failure message. Importing some clips shot with a Canon 5D Mark II [ 24 fps (23.9+)] and PP seems to import them but also gives me a “File Import Failure” and “File format not supported” messages. I’ve tried to input a folder from the flashdisk itself and from a copy on a disk drive. The error message shows up and then all the files also show up in clips in PP.
But something is wrong because when I play the files back in the Source window they play speeded up even though PP shows the correct file length.
I’ve tried making a sequence set to 24 fps (23.9+) and same thing happens.
    Sure would like to get started . . . this is probably a simple thing.
    I’m using the 30-day trial of PP.
    Can anyone help?
    Many thanks,
    Robert
    It’s an MBP with 2.6 ghz i7, 8 g ram, OS 10.8. PP v 7
    Robert Withers replied 13 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
