Activity › Forums › Apple Final Cut Pro Legacy › Clip names vanish in FCP timeline
  • Clip names vanish in FCP timeline
    Posted by David Jakubovic on June 2, 2011 at 1:12 pm
    I’m cutting a show and every once in a while I email the project to the director who reviews the timeline on his FCP, on another computer.
    Then when he sends it back, there are no clip names in the timeline. This might be so banal and so simple but for the life of me I can’t find the setting, and I’ve researched too! Anyone?? Is there a setting that would make clip names go on and off in the timeline or is it some bug? If I turn on thumbnails only it shows the thumbnails, if I set it to thumbnails+names it still shows only the thumbnails.
    Thank you,
    David
    David Jakubovic replied 15 years, 3 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    June 2, 2011 at 1:46 pm
    No setting I know of would cause this permanently… so it’s not that.
    Sounds to me like the project file is getting corrupted, or isn’t from the exact same versions? of FCP 7?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • David Jakubovic
    June 2, 2011 at 1:52 pm
    Yeah they’re both FCP 7 – it’s so weird – the project works just fine when it comes back from him, it just doesn’t have the clip names. Also, if a project originates on his computer and he then passes it on to me it’s the same thing.
    “We’ll fix it in post”
  • Jerry Hofmann
    June 2, 2011 at 1:56 pm
    I meant are both 7.0.3? This was reported about a week ago here I think too… Bet there’s a bug between certain versions of FCP, and/or certain CPU’s, OR someone needs to perform a clean install…
    Jerry
    Current DVD:
  • Michael Griggs
    June 2, 2011 at 3:22 pm
    Is it just in your timeline? or across your project….?
    The timeline has options:
    User prefs –> timline options –> Thumbnail display –> (drop down menu) options are: Name, Name plus thumbnail, Filmstrip
  • David Jakubovic
    June 2, 2011 at 3:37 pm
    It’s on all timelines that have been opened on his computer.
    Yeah I did change that setting but it doesn’t do anything. No names anywhere!
