Activity Forums Adobe Premiere Pro Clip marker – shortcut for each color of marker
  • Clip marker – shortcut for each color of marker
    Posted by Veronique Barbe on January 11, 2016 at 11:50 pm
    Did anyone find a way to assign a shortcut to each color of clip marker in Premiere CC 9.1 ? (like in Avid or Final cut)
    By now, I have to change the color of the marker in the marker window each time I add a new one… a big waste of time.
    NB : I know chapter markers have a different color but they are sequence markers, and I only want to use CLIP markers.
    NB 2 : clip colors – I already use different clip colors so it wouldn’t be a solution to replace the markers.
    Hope there is a solution,
    Thanks !!
    Véronique Barbe
    Monteure | Editor
    https://vimeo.com/veroniquebarbe
    Graham Withers replied 7 years, 7 months ago 4 Members · 4 Replies
  • John Baumchen
    January 12, 2016 at 1:57 am
    I share your pain. It doesn’t seem like it would be a hard thing to allow one to select a default color for markers, but then, I do remember when they were only one color.
  • Veronique Barbe
    January 12, 2016 at 2:08 am
    Thanks John !
    I will fill a request to adobe.
    https://www.adobe.com/products/wishform.html
    Having shortcuts for each color of clip marker should be a basic thing to have.
    Cheers,
    Véronique Barbe
    Monteure | Editor
  • Clarke Leland
    March 1, 2016 at 8:27 pm
    It may not be possible to have a single key to set say a “red” marker. But you can set a key to change the color after its been placed (pressing “M”)
    I just found this out, you can go to the keyboard shortcuts and assign a quick key for “marker color #1”, “marker color #1”, etc. These correspond to the arrangement, left to right, of markers in the marker window. #1 is Green, #2 is Red, so on and so forth. Not exactly the trick, but hopefully it will speed up the process.
  • Graham Withers
    January 14, 2019 at 10:01 pm
    I’m with ya as well! Any progress on this one since you submitted the req?
