Activity Forums Apple Final Cut Pro Clip louder than it should be if pan mode set to “none” vs Stereo Left/Right
  • Clip louder than it should be if pan mode set to “none” vs Stereo Left/Right
    Posted by Matt Wilson on June 30, 2017 at 8:16 pm
    Hi all,
    I’m curious if someone can shed some light on this. I pulled in a pink noise sample (this is a sound sample that is constant noise at -20db). I then pulled up the Multimeter in FCPX (via the Audio effects, Speciliazed option). I played the sound sample clip and the RMS level on the meter (the one that handles averages…versus peaks in the normal meter) showed it pegged at a consant -15 db. After scratching head for awhile, I tried a few things, and switching the pan mode of the clip from “None” to “Stereo Left/Right” caused the clip to come in at the -20db it should.
    Does anyone know why the clip will play too loud if Pan Mode is set to “None”? I guess I need to set all my clips to Pan Mode “Stereo Left/Right” at the beginning of an edit? Am I missing something here?
    Matt
    Matt Wilson replied 9 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
