Activity Forums Avid Media Composer Clip location drive name “changed” in bin… how do I edit this info?
  • Clip location drive name “changed” in bin… how do I edit this info?
    Posted by Nick Boxer on December 20, 2014 at 9:29 pm
    Moved to a new computer temporarily as I transition to newer version of MC.
    Opened projects and in each one a few random clips show as off line. Red in the time line. Went into statistics and saw that each of these clips showed a “drive” name change from “G-RAID” to “G-RAID 3”
    Search the G-RAID drive and the clips are there. Never had 2 drives hooked up while working on these projects.
    How do I change the drive name in the Clip/statistics/info?
    Editing on MC 5.5 on an intel mac running 10.6.8… yeah I know it is time to update, and this is part of my effort to consolidate my old projects and move them to a new platform so I can still access them if I have too. Thanks.
    Michael Phillips replied 11 years, 9 months ago 2 Members · 3 Replies
  • Michael Phillips
    December 21, 2014 at 3:32 pm
    That is not an editable field, only a metadata display field. You might want to delete the msmFMID.pmr and msmMMOB.mdb files from each of the Avid MediaFiles/MXF/ folders and have Media Composer rebuild them upon launch and see if that helps your situation.
    Michael
  • Nick Boxer
    December 21, 2014 at 4:52 pm
    Thanks. Suspected as much. Just the weirdest thing. Clips are stillthere… Or effects. Video, photos and music are on the drive. MC is just attributing them to a different drive with the number “3” attached. Every hear of this happening?
    Rebuilding the database files was my next thought, so I appreciate that you said that. Know it’s likely irrational, but I always feel like I’m going to mess things up doing that.
  • Michael Phillips
    December 21, 2014 at 6:17 pm
    MC always verifies and rebuilds as necessary on startup, so it may be that it just needs to be reminded to do a complete one.
    Michael
