Activity › Forums › VEGAS Pro › “Clip fit” can do?
  • “Clip fit” can do?
    Posted by Kelly Griffin on March 25, 2011 at 10:41 pm
    I’m not sure what this feature is called in Vegas, but here’s what I’d like to know how to do:
    Picture a video clip “B” sandwiched between video clips “A” and “C”, with 15-frame fades on both ends of “B”.
    I would like to cue the entire “B” clip sooner or later, keeping its existing duration, keeping its position relative to “A” and “C” and keeping its 15-frame fades on both ends.
    How to do, and what’s it called?
    THANKS!
    Graham Bernard replied 15 years, 6 months ago 3 Members · 6 Replies
  • Mike Kujbida
    March 25, 2011 at 11:03 pm
    It’s called a slip-trim.
    Click the event to select it.
    Hold down the Alt key (notice the cursor change) and slide it right or left to change the in/out points.
    The preview window will also change to show you these same points.
  • Kelly Griffin
    March 26, 2011 at 12:57 am
    Groovy, thanks Mike!
  • Kelly Griffin
    March 26, 2011 at 1:52 am
    So, where does Vegas show me how many frames I’m slip trimming? I see the in/out image in the preview window, but no indication of how many frames I’m moving either direction (?)
  • Mike Kujbida
    March 26, 2011 at 2:47 am
    Kelly, all I can suggest is adding the timecode FX to the event to see how much you’re slipping it.
  • Kelly Griffin
    March 26, 2011 at 4:16 am
    Hmmm… well, that gave me timecode but nothing changed after I made a change. This looks like a feature that got stopped short of the finish line…
  • Graham Bernard
    March 26, 2011 at 7:16 am
    Kelly, read this over o the SONY Forum. It this what you’ve found? If so SONY is promising to fix it:-
    https://www.sonycreativesoftware.com/forums/ShowMessage.asp?ForumID=4&MessageID=755232
    Grazie
