Activity Forums Apple Final Cut Pro Legacy Clip audio imported out of sync
  • Clip audio imported out of sync
    Posted by Michael Garske on February 26, 2008 at 10:29 pm
    Hi, I have a number of DVCPro HD 720p24 clips that imported with out of sync audio. I’m not sure why this is because some and not others are out of sync. Could it be due to the # of clips that I imported at once? I brought them all in simultaneously and there must be 200 of them. Is there anything I can do to sync the sound besides importing the bad clips again? Thanks.
    Mike
    Michael Garske replied 18 years, 6 months ago 2 Members · 2 Replies
  • Sean Oneil
    February 27, 2008 at 6:41 am
    That sounds unusual. All I can say is you should really try to discover the root of the problem, rather than manually fix it.
    Sean
  • Michael Garske
    February 27, 2008 at 4:11 pm
    Yeah I went back & manually fixed the problem. Not the most ideal solution but better than chasing some ghost in the machine. Thanks for the response.
