Activity Forums Adobe Premiere Pro Client request for 27GB video to compress to 1GB
  • Client request for 27GB video to compress to 1GB
    Posted by George Strother on March 17, 2019 at 10:31 pm
    A client is requesting Full High Definition video at 1920 x1080 60fps, because that is the best, then compress the footage to1GB, because it’s necessary for streaming.
    Am I missing something here, or is this pointless?
    George
    Light Images
    Bouke Vahl replied 7 years, 5 months ago 3 Members · 3 Replies
  • George Strother
    March 17, 2019 at 10:34 pm
    I left out the video will be a little over 1hr 30min, continuous.
    George
    Light Images
  • Oliver Peters
    March 18, 2019 at 12:24 am
    Why at 60fps? 1080 @ 60 is not a common mastering or delivery standard.
    If the client needs it to be 1GB, then you have no choice but to compress it a massive amount. It will either be smaller, have a lower frame rate, or have tons of compression artifacts – or all 3. You can certainly stream videos with much less compression and be fine, but it really depends on target delivery system or internet speeds.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Bouke Vahl
    March 18, 2019 at 4:16 am
    I disagree.
    With H265 this should be very well possible.
    (and with long GOP codecs, the framerate does not matter that much.)
    Bouke
    http://www.videotoolshed.com
