Activity › Forums › Apple Final Cut Pro Legacy › Clicking in MP3 files in FCP 6.0
Posted by Jared Smith on October 25, 2010 at 2:25 amHey guys,
I cannot get a better version than MP3 in time for a premiere on Friday. Is there any way to get the clicking noise out of the track or is that just the disadvantage of dealing with such a low quality file?
thanksJared Smith replied 15 years, 10 months ago 5 Members · 7 Replies -
David Roth weiss
October 25, 2010 at 2:29 amSure you can, just transcode using iTunes or something else.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Colorist – UP IN THE AIR (electronic press kit) – nominated for six academy awards
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Jared Smith
October 25, 2010 at 2:30 amthe song was imported from itunes and is doing it??? should i transcode it as a wav and pull that file into fcp instead? i know it won’t heighten the quality but will it get rid of the click?
Ravi Bayanker
October 25, 2010 at 2:32 ami’m having the exact same problem. the audio sounds ‘clippy’; sometimes. I tried using a low pass filter and I think it sort of helped but yeah… do I need to be using wav files instead of mp3s? And what does the guy below mean by transcode?
David Roth weiss
October 25, 2010 at 2:38 amIt will keep it from clicking if you can transcode a with iTunes protection. I’m not sure if that works or not. Aiff is better than WAV, but bot are better than MP3.
David Roth Weiss
Los Angeles
Martin Curtis
October 25, 2010 at 4:11 amFind the track in the Finder. Open it in QT7 Pro. Export as AIFF. Use that.
Michael Gissing
October 25, 2010 at 4:32 amTranscode means convert from one codec to another. In this case an mp3 should be converted to a aif file @ 48khz sample rate. FCP is really only happy with uncompressed audio (aif or wav) and 48khz sample rate.
There are various ways to convert – itunes, Compressor or quicktime pro are a few options built into your system
Jared Smith
October 25, 2010 at 4:42 ami had luck by simply going to itunes, clicking the song that i am wanting to use and then up at the top use “advanced” and then change it to an aiff
no clipping for me anymore
