Activity › Forums › Adobe After Effects › Cleaning Up Scripting
  • Mylenium
    February 16, 2007 at 7:54 pm
    Check your system’s firewall/ security settings. If you have enabled “Allow scripts to access network…” in AE’s prefs, yet your firewall is blocking its port, it may hang. The same could be true without the option enabled, if soem tool is blocking disc access for scripts.
    Mylenium
    [Pour Myl
  • Jonathan Alexander
    February 16, 2007 at 8:11 pm
    Cool, thanks Mylenium, I’ll check out the prefs and see if it changes anything.
