Activity Forums Apple Final Cut Pro Legacy Cleaning up post completion
  • Cleaning up post completion
    Posted by Brian Martens on July 22, 2009 at 12:52 pm
    Does FCP have a built in way to clear out the audio cache, etc. files it creates for each project or must it be done manually via Finder? If it’s via Finder can someone venture an explanation as to why such a robust product as FCP does not have a built in management window to clean those files out?
    Patrick Jones replied 17 years, 2 months ago 3 Members · 2 Replies
  • John Fishback
    July 22, 2009 at 5:19 pm
    You can delete renders with the Render Manager in the Tools menu. Not sure about an audio cache.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Patrick Jones
    July 22, 2009 at 8:18 pm
    John,
    You are the man! Your wisdom rocks!
    FCS 1 – MBP 2.93ghz 4gb RAM, 300gb 7200 Internal HDD, iStarUSA Dual Dock with (10) 1TB 3.5 Seagate Barracuda drives, and a couple 250’s Maxtors, and Seagates.
