Activity Forums Apple Final Cut Pro Legacy cleaning up audio distortion
  • cleaning up audio distortion
    Posted by David Scherzer on January 28, 2009 at 5:31 pm
    Hey all,
    Quick question. On one of my interviews, the wireless went out of whack and shot the levels too high.
    So not sure on which audio filer at which setting i should use to reduce the distortion. It’s not terrible as is..but noticeably not as clean as the other sound i got that day.
    Thanks in advance…
    David Scherzer
    John Fishback replied 17 years, 7 months ago 3 Members · 2 Replies
  • James Weber
    January 28, 2009 at 5:39 pm
    You may be best sending it to SoundTrack Pro. They have a bunch of analyzing methods that can take out pops and cracks, and may be able to smooth it out some. But the sad truth is that beyond manually redrawing the wave forms, there isn’t really much you can do when audio is clipping, because the levels were too high. There’s a lot of info that just got cut off at the top, because there was nowhere else to go.
    Hopefully someone else will have more detailed/helpful advice.
    Final Cut tutorials from around the web- all in one place.
    https://www.fcptutorials.com
    https://www.jamesnweber.com
  • John Fishback
    January 28, 2009 at 7:22 pm
    There are a number of solutions that can restore clipped audio.
    https://www.cutestudio.net/data/products/audio/declip/index.php?sid=0
    https://www.cedar-audio.com/products/cambridge/camdeclip.html
    https://www.izotope.com/products/audio/rx/
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
