Activity › Forums › Adobe Illustrator › Cleanest workflow to scale-down uneccesarily large AI files
  • Cleanest workflow to scale-down uneccesarily large AI files
    Posted by Phil Muri on May 17, 2006 at 3:26 am
    Howdy Cowpokes,
    Recently, I was given a huge, layered illustrator file. It was so big that every operation involving the file made the otherwise quick G5 (running
    Mike Gondek replied 20 years, 4 months ago 2 Members · 1 Reply
  • Mike Gondek
    May 17, 2006 at 9:42 pm
    Use object >> rasterize to res down your embedded images in illustrator.
    I personally prefer to link to placed images(that taht keeps your .ai’s small & fast), and in that case you can res the image down in Photoshop using imaeg size as you menionted.
    You can also when saving as a .ai turn off PDF compatibility. That checkbox comes up after clicking save on a new file, or use save as to get to the menu on an old file. I know you need that for placing .ai files in InDesign, btu a very very very very wasteful setting that Adobe keeps on by default. I do not rememebr After Effects needing that on, but I could be wrong.
