Activity Forums Apple Final Cut Pro Legacy Clean up bad video compression artifacts
  • Clean up bad video compression artifacts
    Posted by Michael Lansdell on September 8, 2009 at 11:28 am
    I’m putting the finishing touches to a program that uses a lot of archive, most of the sources through the series have been really good, but in the last programme a lot of the clips were only possible to source off DVD and VHS even. These clips have some really horrible compression artefacts, and this problem is being compounded even more by the decision to “arc” the archive for this series (I prefer to keep the original 4:3 or occasionally 1:1 format myself, but it’s not always up to me!).
    To give you an idea of what I’m up against:
    I’ve done a lot of archive shows, and this is the worst by far that I’ve come across. So, does anyone have any ideas, tips, know any life saving software?
    I’m currently going to give Digital Film Tools Composite Suite Pro a try out, but would like to know of any alternatives. I’ll post the results here too, because I’m sure I’m not the only person who’ll ever have this problem!
    Michael Lansdell
    Online Editor,
    Available Light Productions Ltd
    My system:
    2 x 3 GHz Quad-Core Intel Xeon
    5GB DDR2 RAM
    512MB ATI Radeon X1900 XT
    OS X 10.4.11
    Final Cut Pro 6.0.4
    After Effects CS4
    Blackmagic Design DeckLink HD Extreme (6.6.2)
    Take a gander at my personal blog:
    http://www.monstersareart.blogspot.com
    Rafael Amador replied 16 years, 12 months ago 2 Members · 1 Reply
  • Rafael Amador
    September 8, 2009 at 12:29 pm
    Hi Michael,
    With VHS the only thing you can try is a good capturing.
    A player with Pro Amp and TBC to process the signal and a good capture card. And a good capture codec.
    With the DVD stuff, transcoding to a good codec. 8b Uncompress would be the ideal.
    After you may try something like the MagicBullet “Deartifacter” or the Nattress “Chroma Smooth/Sharpening”.
    I would try as well the Innobits “Video Purifier”.
    rafael
    http://www.nagavideo.com
