Activity › Forums › Adobe After Effects › clean plates using AE
  • clean plates using AE
    Posted by David Del on June 23, 2011 at 10:36 pm
    Can you match move or track a scene with AE and use that information in AE to work on the clean plate process? Will AE give you a 3D camera to work with in this case or do you need something like Mocha to do this? So if I had a character as a stand in for a shot and wanted to paint him out and add a 3D character in, I would need to track the shot, and then take that 3D camera information to create a clean plate to put the CGI character in, right?
    David Del replied 15 years, 3 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    June 24, 2011 at 6:03 am
    AE tracking and Mocha tracking will give you 2d information. For a 3d camera match you need a 3d tracker – Camera Tracker from the Foundry works pretty well in AE. Boujou, SynthEyes and and a few others will do the job as well. SynthEyes has some cool features that enable you to create a clean plate.
    As far as replacing a real person with a 3d character, C4D will allow you to import AE camera data.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • David Del
    June 24, 2011 at 10:37 pm
    Ok, I saw the Nuke could do some of that stuff, so I thought I would ask if AE was capable as well. Thanks
