Activity › Forums › Apple Final Cut Pro Legacy › Clean Install FCP 6.0.5 – what about existing FCP??
  • Clean Install FCP 6.0.5 – what about existing FCP??
    Posted by Stu Aull on April 23, 2009 at 2:22 am
    Hello all-
    just been recommended I should update to FCP 6.0.5 but some bugs in current 6.0.4 suggest I should do a clean install off FCStudio Disc.
    Q: do I/can I need to “uninstall” existing FCP 6.0.4 first?
    or
    manually delete it (and what else??)
    or
    will clean install automatically overwrite existing FCP?
    Stu Aull
    Alaska
    David Roth weiss replied 17 years, 5 months ago 3 Members · 5 Replies
  • David Roth weiss
    April 23, 2009 at 4:06 am
    Stu,
    Your best bet is of course a clean install from the ground up, including the OS.
    Next, comes getting FCP Remover from Digital Rebellion — use that to uninstall — then make sure to fix permissions — then reinstall the suite.
    Finally, the worst concept would be to install over the top of the old suite.
    BTW, please say hi to Mrs. Palin for me, and be sure to wave to our friends over in Russia while you’re at it. Okay???
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Zane Barker
    April 23, 2009 at 4:24 am
    [David Roth Weiss] “Your best bet is of course a clean install from the ground up, including the OS.
    Next, comes getting FCP Remover from Digital Rebellion — use that to uninstall — then make sure to fix permissions — then reinstall the suite. “
    If you do a clean install from the ground up Including the OS, then you would not need to use the FCP Remover app because the clean install of the OS would completely erase the hard drive when you do it.
    Erase and install, it is much cleaner then an archive and install.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Stu Aull
    April 23, 2009 at 4:25 am
    Cool!
    Thanks Dave –
    say “Hi” to Sarah? You Betcha (wink)
    Stu Aull
    Alaska
  • Stu Aull
    April 23, 2009 at 4:30 am
    Understood Zane, thank you-
    my “bug” issue – if that’s what it really was – was my Industrial Noise “FX Factory” FX plug-ins disappeared when installing other noise products. NI techs suggested a bug may have caused this and to re-install FCP before re-installing their FX plug ins…
    Will try the Delete FCP app first and see what happens…
    Stu Aull
    Alaska
  • David Roth weiss
    April 26, 2009 at 8:54 pm
    [Zane Barker] ”
    If you do a clean install from the ground up Including the OS, then you would not need to use the FCP Remover app because the clean install of the OS would completely erase the hard drive when you do it. “
    Zane,
    I think you misinterpreted — I was not giving Stu a three step process, but rather three completely different possibilities, in order of preference. It’s seems pretty obvious that one would not have to use FCP Remover if performing a total wipe of the hard drive.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
