Activity › Forums › Adobe After Effects Expressions › clamping a slider value but having two different effects for ‘above’ and ‘below’ the limits
  • clamping a slider value but having two different effects for ‘above’ and ‘below’ the limits
    Posted by Jim Lefevre on March 14, 2012 at 11:57 am
    I’ve not really used the clamp expression much so I may be starting on the wrong footing here but…
    I have a slider (CLOUD_position_DRIVER) with values 0 to 100
    when CLOUD_position_DRIVER < 0 I want CLOUD_position value = 0
    and
    when CLOUD_position_DRIVER > 100 I want CLOUD_position value = 100
    but obviously in between those two ranges (CLOUD_position_DRIVER between 0 and 100) I want the position to be a variable value.
    So basically I want to clamp it so that below a certain value it reads a fixed first state, between the value a variable state and after a certain value a third fixed state (different to the first fixed state).
    I’ve tried…
    if (effect(“CLOUD_position_DRIVER”)(“Slider”)<0) {0} else {value};
    if (effect(“CLOUD_position_DRIVER”)(“Slider”)>100) {100} else {value};
    but it’s not working, or rather the second statement is working but not the first! Which is why I was thinking that the clamp thing might be something I need? Maybe not?!
    many thanks in advance
    jim
    http://www.jimlefevre.com
    Jim Lefevre replied 14 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 14, 2012 at 5:20 pm
    clamp() should work nicely, like this:
    clamp(value,0,100)
    Your expression would have worked if you had use else if(), like this:
    if (value < 0){
    0
    }else if (value > 100){
    100
    }else{
    value
    Dan
  • Jim Lefevre
    March 19, 2012 at 9:26 am
    Ahhh… a stacked if – else -if
    That’s the puppy.
    In actual fact I managed a bit of a work around in the meantime which is far less elegant which pre-works-out a value before it heads into the main if statement
    if (SLIDER_value < 0) then {VALUE_onoff = 0} else {VALUE_onoff = 100);
    VALUE_var = SLIDER_value;
    if (SLIDER_value > 0) then {VALUE_var} else {VALUE_onoff)
    but I’ll go back in and try that other suggestion for the sakes of personal education.
    Thank you thank you thank you
    x
    jim
