Activity Forums VEGAS Pro Clamp video highlights at 100 ire
  • Clamp video highlights at 100 ire
    Posted by Larry Brewer on February 13, 2011 at 9:42 pm
    What is an easy way to simulate an analog video proc amp to limit highlight to 100% so I can bring up the brightness in the midtones. Is there a video event FX that will do the trick? I’ve already played with color curves. Not quite there yet.
    Larry Brewer replied 15 years, 7 months ago 2 Members · 2 Replies
  • Ben Edwards
    February 13, 2011 at 10:09 pm
    Sony Levels is the filter you need to use for each event. Get up the Vector Scopes and use the waveform monitor. you should have stuff touching 100 (black) and 0 (white). Google for ‘sony vegas scope levels’.
    Ben
  • Larry Brewer
    February 14, 2011 at 12:22 am
    Thank you Ben Edwards.
    Should’ve figured that one out myself.
