Activity › Forums › Lighting Design › Clamp for Floresent softboxes to have 2 on a stand
  • Clamp for Floresent softboxes to have 2 on a stand
    Posted by Ben Edwards on March 29, 2017 at 12:46 pm
    Hi. We use photo ‘bulbs’ (the curly ones) with soft boxes to light a greenscreen. currently we have 2 on stands (one each side).
    What we cant to do is have 2 softboxes on either atand (they are verry light).
    Looking for a clamp with a light fitting to clamp onto the stand for the second softbox. Wondering what these are called as cant finds them (we are on a bit of a budget and for this type of thing tend to get hem from ebay).
    Possibly something like https://www.ebay.co.uk/itm/4-5CM-Small-Super-Magic-Friction-Arm-Photo-Studio-Video-Light-Accessory-Clamp-UK-/361553749880? would do if we could find a lighting stalk to screw into the thread (cant quite work out the size of the thread).
    Regards,
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    i5 3550 3.3Ghz, Windows 7 / Mac Lion, Nvida 550 Ti, 16GB Mem
    Todd Terry replied 9 years, 6 months ago 3 Members · 6 Replies
  • Joseph W. bourke
    March 30, 2017 at 6:31 pm
    Here’s a very useful video on different ways to achieve this. Personally, I own a couple of Manfrotto super clamps (pricey), several of the mini-clamps (not Manfrotto and cheap) which are close to 2 inch max opening. A couple of 7 inch magic arms – Chinese, and very good, but not for heavy equipment. A must have is sandbags, which will anchor your light stands, even if they’re light duty. I buy the Giottos small ones from B&H, and then put 2.5 pound weights for weight lifting in them (they hold 2). This method avoids the sand or lead shot, and they’re very easy to work with. Anyway, here’s the video:
    https://dslrvideoshooter.com/studio-part-2-grip-lighting-accessories/
    There are also adapters (Matthews is one manufacturer) called a double-header and triple-header, which would do what you want in one solution, but they aren’t so cheap:
    https://www.bhphotovideo.com/c/product/33186-REG/Matthews_429580_Baby_Triple_Header.html
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Todd Terry
    March 30, 2017 at 7:08 pm
    Hey Ben…
    That piece of gear you linked to is called a Mafer Clamp, and is made for exactly what you are wanting to do. Most of them already have a 5/8″ baby pin attached to them, which is what you’d need.
    If you buy them from B&H or direct from Matthews they can be a slightly pricey piece of hardware, but you can no doubt find no-brand ones on eBay… just search for Mafer Clamp.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Ben Edwards
    April 1, 2017 at 6:31 pm
    Thanks, that’s great. Think we will get a small clamp and a lighting stalk to screw into it.
    Camera Magic Friction Arm Small Super Clamp Crab Pliers Clip Small-size B7G7 (https://www.ebay.co.uk/itm/322466693683).
    1/4″ and 3/8″ Spigot Stud Adapter Male Screw Threaded to Light Stand (https://www.ebay.co.uk/itm/302265923075).
    Can’t find a cheap Baby Triple Header but the price world not of been a big issue. The main reason to go for the above is they are small. We have a large estate (Chrysler) ‘herse’ to carry all the kit and its very full (and we want to add some fresnels and a blond to it).
    Granted its the jib that is the biggest thing.
    Will the above work?
    Thanks for everybody’s advice.
    Ben
  • Todd Terry
    April 1, 2017 at 6:43 pm
    That combo should work.
    Since the baby pin stud has both 1/4″ and 3/8″ threads, and since the clamp has both 1/4″ and 3/8″ receivers… be sure you use the larger ones.
    In a setup like that I’ve had the 1/4″ studs shear off… especially those made of brass. That one doesn’t appear to be brass, but better use the bigger end anyway.
    T2
    Todd Terry
    Creative Director
  • Ben Edwards
    April 1, 2017 at 7:25 pm
    Thanks Todd,
    I almost certainly would of done that but others use the kit. I will leave the studs screwed into the clamp to try to ensure this.
    Ben
  • Todd Terry
    April 1, 2017 at 7:45 pm
    Personally I’d probably just grind that quarter-inch stud off. Fix their wagons from the get-go. 🙂
    T2
    Todd Terry
    Creative Director
