Activity › Forums › Adobe After Effects Expressions › clamp existing wiggle expression
  • clamp existing wiggle expression
    Posted by Ryan Hagen on September 14, 2018 at 3:03 pm
    Here’s the expression im using, I have a Null with expression sliders driving the wiggle, just want to clamp the value so it doesn’t go into negative values, i’m just not sure how to alter the expression to do this. Thanks in advance for any help.
    w = wiggle(thisComp.layer("Master_ct").effect("PerSec")("Slider"),thisComp.layer("Master_ct").effect("Amt")("Slider"));
    [w[0],[29.9]]
    Ryan Hagen replied 8 years ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    September 14, 2018 at 3:48 pm
    I believe the second line would be
    [Math.max(w[0],0), 29.9]
    Note that you don’t use brackets on the second value, brackets are used to create or read an array.
    Senior Graphic Designer
  • Ryan Hagen
    September 14, 2018 at 3:54 pm
    That worked, thank you very much Kalleheikki. Also thank you for helping me to understand the bracket usage.
