City lights reacting to music
The warmest greetings in this cold season!
English isn’t my first language, so please bear with me:
this new project of mine gives me a challenge I can’t solve for myself.
My skill set and understanding of After Effects puts me fairly in the “basic”, or maybe “amateur” section
and because I’m certain that some scripting is required to get this right, I need help.So the basic premise of the project is that I need city lights at night, like streetlamps, to be reacting to musical cues. And since this will be a music video, there’re going to be some.
The shots are purposely almost always vistas, never say in the middle of a lively street so that the contrast between the light and the dark is definite.
Only the opacity (exposure/glow) is affected by the cues, meaning the intensity changes with whatever the instruments, or the vocals are doing.
Available to me are After Effects and the plugin Soundkeys.
I also have the separate tracks for each instrument and the vocals.
So in a scene with 1-30 lights, I’m able to work up a solution that works and looks adequately nice.
But since the finale builds up to the whole cityscape at night, I feel that masking every single lamp or window isn’t the right way to go.
So, is it possible to write an expression that not only distributes the cues, based on the keyframes made by Soundkeys, to already bright spots in the footage without drawing a billion masks, and then even randomising these lights so that not all of them react simultaneously?I’m not sure if I communicated my problem well, but I hope someone gives me a break.
And I thank you for your time in advance!
