Activity › Forums › Maxon Cinema 4D › Circles Rendering Problem
  • Adam Trachtenberg
    March 21, 2017 at 3:50 pm
    It looks smooth here. Are you sure the Picture Viewer is set to 100% magnification? It will look aliased if you zoom out.
    Otherwise you may be just seeing a limitation in your monitor resolution, because the rings are very thin. Maybe at a very slight blur in post.
