Activity › Forums › Adobe After Effects › Circle visualizer assistance needed!
  • Circle visualizer assistance needed!
    Posted by Steven Dowden on December 19, 2017 at 9:15 pm
    Hey guys,
    This screenshot will clearly sum up the issue I’m having. I’ve been dealing with this for a while now and I hate turning down the mirror just to make that not appear because it makes the mirror look off.
    https://imgur.com/a/icvwk
    Any ideas how to make that go away? I’ve tried tweaking the start & end ranges, all the boxes you can check and uncheck. I did right now find a semi-fix, but it’s still adjusting the mirror, just the angle….
    Is there a way to fix it without having to give up quality of the mirror effect on the visualizer?
    View post on imgur.com
    Kevin Camp replied 8 years, 9 months ago 2 Members · 1 Reply
  • Kevin Camp
    December 26, 2017 at 8:35 pm
    i can’t seem to replicate that issue with the mirror effect…. it may just be an artifact that got cached. try choosing edit>purge>all to force AE to re-render cached frames and see if it goes away.
    if not, try doing the same effect and settings on a new layer (some other image or footage you have) and see if the same issue exists. If it does, let us know what version of AE and OS you are using; if not then we’ll need to troubleshoot the layer/comp that mirror is applied to.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
