Activity › Forums › Adobe After Effects › Circle Trim Path Issue
  • Circle Trim Path Issue
    Posted by Ashley Ripka on February 9, 2018 at 4:06 pm
    Hoping someone can help me with this, I’ve never had this issue before and I cannot figure out what the problem is.
    I am animating a circle trim path around a number. Everything is fine until it gets about 75% around and then it glitches. I am attaching a couple screen shots.
    Here’s a before:
    Here’s an after:
    Thanks in advance!
    Dmytro Korolkov replied 8 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Roei Tzoref
    February 9, 2018 at 5:50 pm
    did you by any chance start with a parametric shape and then converted to bezier by right click convert to bezier path? because if so this procedure is buggy for animation unless you re-set the first vertex.
    highlight the path, see where the first vertex is (it has a square box)
    then select just that vertex and right click->mask and shape path>set first vertex.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Ashley Ripka
    February 9, 2018 at 8:51 pm
    I used a shape layer with no fill and a stroke only. I tried what you suggested and it’s grayed out in my menu.
  • Roei Tzoref
    February 9, 2018 at 10:14 pm
    Do you see the path property? Make sure just that vertex is selected.
    Roei Tzoref
  • Roland R. kahlenberg
    February 10, 2018 at 9:15 am
    This is very likely a cache issue. Edit>Purge>All Memory & Cache to see if it helps. If not, then restart AE.
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Ashley Ripka
    February 12, 2018 at 2:34 pm
    Nothing seemed to work, so I just recreated the shape layer with the trim path animation and it seems to be working fine.
    Thank you for trying to help.
  • Ashley Ripka
    February 12, 2018 at 2:35 pm
    That was my first instinct, didn’t work.
    I ended up just recreating the shape layer with the trim path and it seems to be working.
  • Dmytro Korolkov
    July 28, 2018 at 12:42 pm
    cache reset was my resolution. Interesting that Media encorder use AE cache for rendering.
