Activity › Forums › Apple Final Cut Pro Legacy › cinewave/fcp HD – do not mix ntsc and pal output problem
  • cinewave/fcp HD – do not mix ntsc and pal output problem
    Posted by Jason Lam on May 7, 2005 at 2:42 am
    Dear All,
    I’m having this problem … i cant sync up with my decks. I’m using a keyspan usb.
    Running on a Powermac G5 with
    MAC OS X 10.3.5 ,
    quicktime pro 6.5.2 ,
    FCP HD (4.5) ,
    cinewave 4.5
    My cant exit my cinewave preference (apple preference) window. It keeps saying that ‘do not mix ntsc and pal output’. Could this be a setting problem or software version compatibility issue?? How can i solve this??
    Jason Lam
    Jason Lam replied 21 years, 4 months ago 2 Members · 2 Replies
  • Christopher Tay
    May 7, 2005 at 4:25 am
    Jason,
    If you have both the SD and HD breakout box connected at the same time, you have to ensure that the settings for both matches. For example, if you have set your HD breakout box to HD/25, you will need to set the SD to PAL 625. Or if you set HD to HD/24p, you will need to set the SD to NTSC 525.
    Hope this helps.
    -chrispy
  • Jason Lam
    May 7, 2005 at 4:32 am
    actually i have a pro digital breakout box and a pro analogue breakout box… so what kind of settings should i set??
    are you chris tay?? if you are chris, juliet is asking whether would you want to talk through skyPe with me??
