Activity Forums Apple Final Cut Pro Legacy Cinewave offline to online | settings question
  • Cinewave offline to online | settings question
    Posted by Ron Dylewski on August 28, 2006 at 4:04 pm
    Hi –
    If I capture with my Cinewave card using the “YUV to DV” setting as a way to get a lower quality and less disk hungry codec, am I forced into the 720 x 480 space? It seems so.
    I ask, because if I then reingest using a 720 x 486 codec, any graphics, etc will be out of place, no?
    I’m a former Avid type you has done almost on off-lining on FCP, so I’m still trying to get my head around it…
    Ron
    Photos, news, memories and musings on the great American Roadside experience
    https://www.theamericanroadside.com
    Are you a collector? Put your collection online for free at What A Collection.com!
    https://www.whatacollection.com
    Jeremy Garchow replied 20 years, 1 month ago 3 Members · 2 Replies
  • Walter Biscardi
    August 28, 2006 at 4:28 pm
    NTSC-DV is 720×480 frame size. Uncompressed NTSC-D1 is 720×486. So yes, your graphics will require tweaking once you go into the 486 timeline.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jeremy Garchow
    August 28, 2006 at 4:51 pm
    What I usually do is create my graphics in the final frame size I am going to online in (720×486 for SD). I can then adjust as needed in my offline and then when I online I have the final frame size and there’s less tweaking/remaking that I have to do.
    Jeremy
