Activity Forums Adobe After Effects CINEWARE file wrong version for import
  • CINEWARE file wrong version for import
    Posted by Joe Bloemer on May 8, 2017 at 12:58 pm
    This is my first attempt at working with 3d. I figure it’s probably time to learn at least the basics.
    I got a product file from a client in Cinema 4d format and tried to import it into AE. I got the error “AEGP Plugin CINEWARE Scenelayer: CINEWARE – Document was saved in version R11 or older. Please resave with a newer version of Cinema 4d.”
    Is it really that simple? Can Cineware not open older files of it’s own format? Seems odd.
    This may be the case but before I tell the client I need a different file, I thought I’d check here. I see a lot of people posting problems with Cineware and thought maybe someone may know a solution not involving going back to the client, or having to install Cinema 4d.
    Learning something new every day. Thanks for any direction.
    Joe Bloemer replied 9 years, 4 months ago 1 Member · 1 Reply
  • Joe Bloemer
    May 10, 2017 at 12:00 pm
    For anyone stumbling across this in the future. ..
    The fix for me was to not import the file directly into After Effects, but to create a C4D project first and import it into that.
    That worked perfectly.
