Activity › Forums › Maxon Cinema 4D › Cinema4D noise
  • George Lazarev
    October 25, 2015 at 4:33 pm
    btw, yes i did try changing noise scale but for such big objects it gives no effect. I initially tried with an extremely big plane (typed in like 999999999999999 and it changed it to the max value(?)) but even with something less big it just doesn’t work.
  • Brian Jones
    October 25, 2015 at 5:05 pm
    I have to guess you made the plane that big without increasing the height and width segments – if you have a noise that works well on a normal plane (400×400 with 20 wide 20 height segments) each segment is 20×20 units. If the noise is what you want with that, the segments need to remain 20×20 units, so if you make the plane 10 times bigger you need to have 10 times more segments each direction so they stay the same 20×20 units in size
  • George Lazarev
    October 25, 2015 at 6:42 pm
    Yeah, it worked. Though i reached it’s limits – 20000×20000 sizes / 1000 segments and sadly i need something to reach the horizon and FYI my camera i use is also 20000 cm higher than the water (plane).
    https://i.imgur.com/JiPxCAy.jpg – kind of an island in the sky idea. as you can see i need more detail on water
    View post on imgur.com
