Activity Forums Apple Final Cut Pro Legacy Cinema Tools export problem
  • Cinema Tools export problem
    Posted by Chris W. hill on November 2, 2006 at 8:34 am
    I edited a show shot on 35mm film, I imported my ALE files from Cinema tools, and all of the information is correctly attached to each clip in the bin, but the second I drag a clip to a timeline and right-click on that clip again, the keycode numbers are gone! They are there in the bin, but gone in the timeline so I can’t output a cut list.
    I am hoping someone here can shed some light on this. Thanks in advance for any advice.
    Steven Gonzales replied 19 years, 10 months ago 2 Members · 1 Reply
  • Steven Gonzales
    November 2, 2006 at 4:06 pm
    I don’t understand what is disappearing when you right click a clip in the timeline.
    Have you tested whether you can make a cut list or not? Put a couple portions of clips in the timeline. Select the sequence, go to File – Export – Cinema Tools Film List, pick your settings and see what happens.
