Activity › Forums › Apple Final Cut Pro Legacy › Cinema Tools crash on connect clips
  • Cinema Tools crash on connect clips
    Posted by Steven Gonzales on August 11, 2010 at 3:36 pm
    I’m having a problem with Cinema Tools crashing on a batch “connect clips.” I’ve tried in 10.5 and 10.6, updated Cinema Tools to the latest pro update, and still a problem.
    I have a database made from one videotape. I manually connected each clip one at a time. Now I moved the folder to test “connect clips”. So this is a database that knows the exact name of the clip it needs to connect to.
    Every time, crash report screen appears.
    Anyone have a clue on this issue? I have 2000 clips to connect, and I have 2 systems with (unfortunately) different file structures, so connecting 4000 times to get a decent report out of Cinema Tools is out of the question.
    I’ve done several films with Cinema Tools starting with Film Logic in 1999, so I’m not a novice to the program. It just appears to be broken.
    Steven Gonzales replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
