Activity › Forums › Apple Final Cut Pro Legacy › Cinema Tools conversion question
Posted by Christian Remde on June 11, 2010 at 10:16 pmHello,
I’m editing a FCP sequence where 98% of all the footage was shot 23.976. There are some shots which were mistakenly shot at 29.97 and I’m looking for a step by step breakdown on how to convert the 29.97 to 23.976 in Cinema Tools.
I did a search here on Creative Cow and couldn’t find anything, so any help you can give would be very appreciated.
Christian
John Fishbackreplied 16 years, 2 months ago 4 Members · 7 Replies
Rafael Amador
June 12, 2010 at 2:22 amCinemaTools is not your way.
With CinemaTools You would get your 29’98 footage slow down a 20%.
You need Compressor or Mpgstreamclip.
Rafael -
Christian Remde
June 12, 2010 at 3:03 amI have Compressor…is there a certain preset I should use?
Right now, the 29.97 footage is DVCProHD 1080p30 at 1280×1080. I’d like the final footage to be Apple ProRes 422 1920×1080 at 23.976.
Is it just as simple as applying the Apple ProRes 422 preset in Compressor, making sure the frame rate is 23.976 and hitting go or do I need to do something else?
John Pale
June 12, 2010 at 5:55 amTurn the Frame Controls on and set the Rate Conversion to Better or Best.
This might take awhile. A long while.
John Pale
June 12, 2010 at 5:37 pmBest might be overkill in this case. He’s really only rescaling the DVCPROHD pixels, not doing a full on upconversion from a non HD source. Do a short test using normal or better and see if it works for you. The difference in encoding time is tremendous with everything set to Best…so choose wisely.
John Fishback
June 13, 2010 at 12:07 amAlso up the quality setting for rate conversion.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
