Activity Forums Apple Final Cut Pro Legacy Cinema Tools Audio EDL from 23.98 timeline with 30NDF source audio
  • Cinema Tools Audio EDL from 23.98 timeline with 30NDF source audio
    Posted by Carsten Kurpanek on April 7, 2010 at 9:37 pm
    Hey there,
    ilm was shot 35mm, telecined to DVtape 29.97, but reversed telecined it in FCP to 23.98. Database is fine. All burn-ins match the database (see screengrab for take 172B-2: https://www.carstenkurpanek.com/172B-2.jpg).
    Now, if I do an audio EDL, I can either do a 24 TC EDL which has all the source TC wrong (which is 30NDF) and the sound guys are not able to get the correct production audio, but the target TC correct (timeline is 24 after all). Or I do a 30 NDF TC EDL which has all the source TC right, but now the target is wrong… all clips are a couple of frames of because of the different frame counts of 24 and 30NDF.
    Sample from the 30NDF AUDIO EDL:
    001 23 A C 16:19:48:02 16:19:48:05 05:06:03:03 05:06:03:06
    * FROM CLIP NAME: X173C-1/D
    * SCENE X173C TAKE 1
    002 23 A C 17:01:34:21 17:01:35:26 05:06:10:04 05:06:11:09
    * FROM CLIP NAME: X173D-3/D
    * SCENE X173D TAKE 3
    -> Here is the source TC correct.
    Sample from the 24NDF AUDIO EDLS:
    001 23 A C 16:19:45:21 16:19:45:24 05:06:03:02 05:06:03:05
    002 23 A C 17:01:33:14 17:01:34:12 05:06:10:03 05:06:11:07
    -> Here is the target TC correct.
    Is there a way to combine both information, the correct 30NDF source TC with the correct 24 target TC? Or did I simply do something wrong here?
    C.
    http://www.carstenkurpanek.com
    Jay Trautman replied 16 years, 3 months ago 4 Members · 5 Replies
  • Matt Lyon
    April 8, 2010 at 4:19 am
    Carsten, are you using Cinema Tools to generate the EDL? You’re going to want to do a 30 NDF audio EDL, since that is the timebase of the source media. To be honest, it’s been a while since I’ve done this, but I never recall it being an issue. I would talk to the sound folks and you’ll probably find out it is less of an issue than it seems.
    FWIW, I usually am asked to deliver OMFs first and foremost, with EDLs as backups (I suspect they are rarely used).
    You should also give them reference audio, so they can ensure that sync is maintained during their conform.
    Hope this helps,
    Matt Lyon
    Editor
    Toronto
  • Carsten Kurpanek
    April 8, 2010 at 5:07 am
    Hey Matt,
    Thanks for the response. Yes, I’m using Cinematools to do the audio EDL. Since this is a feature and we cut only with a reference audio (a mono mixdown), sound will have to rebuild our audio timeline with the actual multi channel audio from set. So in this case, the OMF is only the back up. I did give them an OMF and a QT for video reference.
    The sound house is running a 23.98 project in ProTools. We cut in 23.98 in FCP. If the audio guys on set would have used 24 TC on the audio instead of 30 NDF, I could export a 24 TC audio EDL and the source and target TC would be spot on. However, since they recorded 30 NDF TC for the audio on set, I have to export a 30 NDF audio EDL. This, however, causes the target TC in that EDL to be slightly off by 1 to 6 frames – which makes sense of course.
    So the 30NDF AUDIO EDL gives me the correct source TC (which originally was 30 NDF), but the wrong target TC (it gives me a 30 NDF frame count, although I’d need a 24 TC count to be spot on).
    This is the same clip in a 24NDF AUDIO EDL:
    The source is now by 3 seconds off, but the target is right on.
    Basically, what I need would be a combination of both:
    001 23 A C 16:19:48:02 16:19:48:05 05:06:03:02 05:06:03:05
    I could do this manually of course, but that’s a lot of work. I was hoping I did something wrong somehow and it’s an easy fix on my end… Doesn’t look like it, though…
    I’m considering importing the EDLs into Excel (or File Maker Pro) and switching out the target TC column, to create my own Frankenstein EDLs…
    Thanks again,
    C.
  • Matt Lyon
    April 8, 2010 at 5:41 am
    Ah, okay… Thanks for the extra info. The scenario you are describing is pretty common. I\\\\\\\’ve done shows this way without problems.
    You CANNOT mix timebases within an EDL … how would the program know which is which?
    Your sound people will be conforming the audio initially in a 30 NDF project, since they\\\\\\\’ll have to ingest media at that TC rate.
    Give them a separate picture only EDL at 24 NDF and they should be able to marry the two after the initial conform.
    And the timecode numbers in the base 30 EDL aren\’t actually that far off. FCP Is just finding the nearest equivalent frame number. So 12 @ 24 fps becomes 15 @ 30 fps. 20 becomes 25, etc. So nothing is ever actually off by more than fractional amounts of frames. 23 @ 24 fps would fall somewhere between 28 and 29 @ 30 fps, for example.
    Matt Lyon
    Editor
    Toronto
  • Jim Blokland
    April 9, 2010 at 4:17 am
    Hi Carsten:
    It’s been awhile since I’ve done this, but if memory serves correct what you need to do is copy the audio from your sequence (or reels) and paste it into a new sequence with a 30 NDF timeline. Then export a CinemaTools audio EDL from there, and you should be good to go. You’ll notice that FCP does a bit of acrobatic trimming with the clips sometimes to make them conform, but you’ll be a great deal closer to having a good EDL for your sound guys to conform with.
    Hope this makes sense/suits your situation.
    Best, JIM.
    OSX.5.6
    Dual 2.7 G5
    5.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.5 TB RAID
    AVID XPRESS PRO/MOJO
  • Jay Trautman
    June 4, 2010 at 6:01 pm
    Carsten,
    I’m having exactly the same issue. Did you find another workaround, or was your sound house able to work with not quite frame accurate master TC? I find it somewhat amazing that I can specify 24fps picture and 30NDF sound in my cinema tools database, and the thing still counts frames from the top of the clip and gets confused about whether to divide by 24 or 30.
    Hope you’re well!
    Jay
