Activity Forums Apple Final Cut Pro Legacy Cinema Tools 29.97>23.98 EMERGENCY : (
  • Cinema Tools 29.97>23.98 EMERGENCY : (
    Posted by Sean Kapleton on March 26, 2010 at 3:57 pm
    Hello,
    I have some 1080i 29.97 upper fields footage that needs to be converted to 23.98 but I am having no luck with Cinema Tools : (
    I have taken a :30 second piece of the 1080i footage and tried each of the Fields Styles but no matter what the footage plays back funny (viewing in the canvas at 100%). My co-worker was sure one of these patterns would work and originally we counted out the frames to properly determine and not just guess which style to use but that did not work so i went ahead and tried all of the 5 patterns in Style 1 with capture mode set to Field 1- Field 2 (upper).
    Now it seems that i will have to take each individual shot from the edit and bring into AE and remove pulldown which is a total bummer and very tedious time consuming work.
    Any thoughts on what I might be doing wrong or why this is not working ?
    Thank you
    Sean
    Jamie Pickell replied 16 years, 5 months ago 4 Members · 5 Replies
  • Matt Lyon
    March 26, 2010 at 4:32 pm
    Did you make sure you were parked on an “AA” frame in the clip viewer before you hit “OK”? Cinema Tools will assume that the current frame matches whatever part of the cadence pattern you have ticked in the “fields” section of this settings window.
    Matt Lyon
    Editor
    Toronto
  • Joel Peregrine
    March 26, 2010 at 4:46 pm
  • Sean Kapleton
    March 26, 2010 at 5:01 pm
    hey matt,
    so i did not move the in point at all when bringing into CT and its from that first frame that we determined originally how the cadence was – regardless if i tried all 5 versions wouldnt one of them work if I was always parked on the same first frame for all attempts?
    thanks
    sean
  • Matt Lyon
    March 26, 2010 at 5:12 pm
    Sean, I re-read your first post and do I understand correctly that the footage is for material that has already been edited? If that is the case, are you sure the cadence is consistent for the whole clip? IE, does it change at the cut points? Cinema Tools will not auto-detect or compensate for changes in the pulldown cadence mid clip.
    If that isn’t the case, then what you said makes sense … one of those choice ought to work. But are you sure that your footage isn’t “style 2” pulldown.
    You could also try toggling off the “standard upper/lower” check box.
    As a test, you might want to open the clip in CT and find an “AA” frame in the middle of the clip and rerun the reverse telecine and see what happens.
    Matt Lyon
    Editor
    Toronto
  • Jamie Pickell
    March 26, 2010 at 9:05 pm
    If you don’t get Cinema tools to work for you and you have to go through AE, use this script to open your FCP sequence in AE.
    https://www.popcornisland.com/category/final-cut/
    I use this all the time to take an edited sequence into After Effects and apply effects.
    Cheers,
    Jamie
