Activity › Forums › Apple Final Cut Pro Legacy › Cinema Tools
  • Posted by Scott Gray on August 8, 2007 at 10:51 pm
    Some footage was inadvertently shot in 24p advanced setting on our HVX200 in DV tape mode. I need to use the footage in a 23.98 sequence using FCP, but know matter what I do the motion in the video looks choppy. Using Cinema Tools, I can’t produce a clean 23.98 conversion using Reverse Telecine. When I choose the conform the video and audio slows. Does anyone have a solution, or know the proper settings in the Reverse Telecine options box?
    Jeremy Garchow replied 19 years, 1 month ago 2 Members · 3 Replies
  • Jeremy Garchow
    August 8, 2007 at 11:10 pm
    Remove advacned pulldown should do it, or you can recapture using the DV remove advanced pulldown easy setup in FCP Hit control-q and select the show all box).
    Jeremy
  • Scott Gray
    August 9, 2007 at 12:58 am
    I tried both suggestions and the processed files still do not have smooth motion. Thanks for your response, but I’m at a loss.
  • Jeremy Garchow
    August 9, 2007 at 1:10 am
    It’s different than 24p motion? can you post a small sample in Dv form?
