Activity › Forums › Maxon Cinema 4D › CINEMA 4D v20 – C.O.F.F.E.E. Warning
  • CINEMA 4D v20 – C.O.F.F.E.E. Warning
    Posted by Sam Hernandez on February 4, 2019 at 6:43 pm
    Hello,
    Need help. What does this mean? Will my project still work?
    Created in C4D v17 opening in C4D v20
    Softboxes used (2) do have XPresso
    This project contains 2 old C.O.F.F.E.E. elements which are no longer supported: – Xpresso C.O.F.F.E.E. Nodes: 2
    Thanks in advance.
    _sam
    _sam
    Sam Hernandez replied 7 years, 7 months ago 2 Members · 4 Replies
  • Brian Jones
    February 4, 2019 at 11:42 pm
    probably there is a Coffee node in the xpresso. Coffee was deprecated so no longer works. xpresso does and python does but xpresso that uses a Coffee node would break. No way around it except to update. Are those greyscalegorilla softboxes?
  • Sam Hernandez
    February 5, 2019 at 9:42 pm
    Appreciate your response. Yes, they are GSG SoftBoxes.
    _sam
    _sam
  • Brian Jones
    February 5, 2019 at 10:07 pm
    GSG updated their stuff to work with 20, you can dl the latest version on your download page (on their site) I assume the light kit is part of that
    https://greyscalegorilla.com/2018/09/compatible-plugins-c4d-r20/
  • Sam Hernandez
    February 6, 2019 at 11:26 pm
    Brian,
    Thanks will look into this.
    _sam
    _sam
