Activity › Forums › Maxon Cinema 4D › Cinema 4D turning Globe
  • Cinema 4D turning Globe
    Posted by Qader Eshpari on December 4, 2015 at 10:23 pm
    IMac 16GB Ram
    El Capitain.
    Hello all,
    As you see, I am a new member to this forums, hope to have good experience here…
    My question is : I was trying to create a turning globe, which is a simple thing for most of you all..
    I started a new project > then I selected Sphere > then I double clicked on the lower left timeline > I added my effects and then I dropped a picture on the Sphere ,..
    Now I am trying to set a keyframe for the 1st position and then I changed the position and I created another keyframe , but when I try to hit the play , it don’t do anything
    Any help will be appreciated ..
    Brian Jones replied 10 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    December 5, 2015 at 6:14 am
    you don’t say but you definitely have to make a keyframe at one point in the timeline then move to a different time in the timeline (different frame) then animate the object (move/rotate/scale etc) then make a new keyframe. If you don’t move the timeline in-between keyframes you just over-write the first one and there is no animation
