Activity Forums Maxon Cinema 4D Cinema 4D to After Effects
  • Cinema 4D to After Effects
    Posted by Anthony Wilson on October 3, 2014 at 12:31 am
    I need some help I am rendering a jumbo tron like object with 4 side that are separate screens I used compositing tags and external compositing tags with solids, so I can just change them multiple times in AE, on each screen and render the project out with the object buffers. When I open the aec file in after effects as the camera rotates around the jumbo tron I can still see the backes of the other solides through the screen not the solid that is facing the camera. I need help to make it where whichever screen is facing the camera is the only onevisiable ?
    Emir Bojorquez replied 11 years, 11 months ago 2 Members · 1 Reply
  • Emir Bojorquez
    October 3, 2014 at 6:19 am
    For what you describe, looks like you need to make 4 different object buffers, one for every screen.
    and then apply it to every Solid.
    Good Luck
    Imagination is the best tool…
