Activity Forums Maxon Cinema 4D Cinema 4d sky shader
  • Cinema 4d sky shader
    Posted by Gustavo Perez rangel on April 23, 2010 at 11:47 pm
    i am new to cinema 4d, I’ve watched tutorials about the sky shader, where you can change de hour, day, clouds, etc. but when I add a sky element it only shows basic and coord in the atributes, ive double clicked the sky icon and nothing, I have installed advanced render , I think, because I can use global illumination etc, is it correct?, is there something I need to activate in order to use the other atributes in the sky? (time, day, etc.) cant seem to find them anywhere, thanks
    Mike Van der noordt replied 16 years, 5 months ago 2 Members · 1 Reply
  • Mike Van der noordt
    April 26, 2010 at 7:36 am
    Hi Gustavo,
    If you choose objects-sky-create sky you’ll have the sky-object with alle the settings you’re looking for. Hope that works for you!
    cheers
    Mike
