Activity Forums Maxon Cinema 4D Cinema 4d shape morph
  • Cinema 4d shape morph
    Posted by Andrew Riss on June 3, 2010 at 1:38 pm
    I am a CD4 newbie
    I was wondering if there is a way to do a simple shape morph
    for example start out with a ski hat and it turns into a circle
    or more complex, start out a guitar and turn into a circle
    any help would be awesome
    thanks
    andrew
    Andrew Riss replied 16 years, 3 months ago 2 Members · 3 Replies
  • Andrew Riss
    June 3, 2010 at 1:42 pm
    I should be more specific
    the objects would all be colored siloeuttes, just simple shapes
  • Adam Trachtenberg
    June 3, 2010 at 1:55 pm
    It’s possible, but it requires that you model the two shapes from the same mesh. It can be done either by recording point level animation (PLA) keyframes, or by using the morph tag (Mocca only, I believe).
    You have to enable PLA keyframing if you want to go that way. It’s the third icon to the left in the icons at the bottom-right of the time slider. Looks like a grid of points.
  • Andrew Riss
    June 3, 2010 at 2:04 pm
    I’ll give it a shot
