Activity › Forums › Maxon Cinema 4D › Cinema 4D Separating Letters in Text
Posted by Thomas Frank on November 19, 2009 at 8:57 amHey,
I am a bit new to Cinema 4D, so don’t bash on me toooo soon! X)
I need to separate the Letters after creating a text and applying the Extrude tool. So I can animate each letter individually.
What is quicks and safest way to do so?Thanks!
Tim Shetz replied 16 years, 10 months ago 3 Members · 7 Replies -
Tim Shetz
November 19, 2009 at 8:59 amIf you have Mograph, you could use the per character option when using Mograph text.
Thomas Frank
November 19, 2009 at 11:52 amYeah but it doesn’t give me enough freedom.
SO is their a simple way to separate the letters?
Adam Trachtenberg
November 19, 2009 at 3:21 pmYes, it’s pretty easy.
* Select the extrude object and run the “make editable” command. That will result in three objects (sides and two caps);
* Select all three and run the “connect” command. That will combine the three objects into one object;
* Run the Functions>Optimize command. That welds the caps to the sides; and finally
* Run the Functions>Explode Segments command. That will give you your separate letter objects.
Thomas Frank
November 19, 2009 at 8:05 pmWow! Easy it might be, but what a workflow.
You would think no days of age it you be a simple click. lol -
Adam Trachtenberg
November 19, 2009 at 9:52 pmSounds worse than it is. ;D
If you use teh MoGraph text object and make it editable it will give you separate extrude nurbs for each letter directly.
Thomas Frank
November 20, 2009 at 8:32 amNot really to familiar with MoGraph, maybe you can send me some tip and hints my way?
Tim Shetz
November 20, 2009 at 8:55 am
