Activity Forums Maxon Cinema 4D Cinema 4D Scene Too Small For AE Track Data
  • Cinema 4D Scene Too Small For AE Track Data
    Posted by Andrew Goode on November 17, 2015 at 9:23 pm
    Hey guys. I’m doing a project where there is an actor in front of a green screen doing various things for all the shots with camera movement and track points. I’m getting a great track in after effects. The problem is, I can’t seem to figure out how to put the actor into the CG set I built in Cinema 4D properly. The CG set is too small. How do I make the scale correct so that I may line things up properly? I’m using After Effects’ 3D Camera Tracker. I’m not seeing any options to make Cinema 4D understand the scale I’m trying to achieve in the plugin.
    Andrew Goode replied 10 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
