Activity › Forums › Maxon Cinema 4D › Cinema 4d Rendering
  • Cinema 4d Rendering
    Posted by Josh Wrenn on October 29, 2013 at 5:49 pm
    Hello all I’m having a problem when I am trying to render something. I have created a sphere that has luminance properties as well as rigid body dynamic enabled. The spheres are basically rolling across a floor. Problem is when I render it out where the balls are rolling it has streaks behind the ball where the light was previously at. How can I get the streaks not in there?
    Cinema 4d R15
    Render settings:
    Output: 1280 x 720
    Save Format quicktime movie
    Global illumination effect is enabled Record density is high smoothing is 50% under irradiance cache
    General preset set to custom primary method irradiance cache secondary method set to none samples set to medium
    here is a link to a frame from sequence: https://f1.creativecow.net/6692/image-for-help
    Adam Trachtenberg replied 12 years, 11 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    October 30, 2013 at 3:21 am
    Do you have “full animation mode” checked in the GI cache settings?
    You might want to try the small illuminant preset.
