Activity › Forums › Maxon Cinema 4D › Cinema 4D R17 problem
  • Brian Jones
    December 15, 2015 at 3:24 pm
    that’s exactly what you should get, default grey. If you want color you can Use Color in the objects Basic tab in the Object Manager (this is temporary, it only shows in the viewport but does not render).
    If you want color that renders add a material.
