Activity Forums Maxon Cinema 4D Cinema 4D R13: Thrausi Falling Text
  • Cinema 4D R13: Thrausi Falling Text
    Posted by Glen Habinbottoms on December 22, 2014 at 2:46 am
    I am trying to create an animation where there is one text, then using thrausi, it changes into another text. This goes well, but when I set the keyframes and press play, the text does the animation, but it falls as it does it. I have tried different ways of doing this, but in the end, they all end up falling. Does anyone know how to fix this?
    Emir Bojorquez replied 11 years, 9 months ago 3 Members · 2 Replies
  • Andy Henik
    December 22, 2014 at 11:41 am
    Fear friend,
    To my knowledge thrausy is a destruction tool, that works with the dynamics module in Cinema 4D. For what I can understand, it works only one way. However you can always ask the guy’s from Nitro4D, who created this plugin. Maybe they can give you a better answer than me.
    If you find the solution for this problem, I’d be interested to know too.
    For what its worth, there is a plugin from GreyScaleGorilla called “Transform”. It is not a free plugin, it costs about 199$ but it might pay off if you have use of this plugin very often.
    heres a link: https://store.greyscalegorilla.com/
    Hope I helped
    alio3d
  • Emir Bojorquez
    December 24, 2014 at 12:58 am
    You just need to delete the Dynamics tag or turn it off.
    Good Luck
    Imagination is the best tool…
