Activity › Forums › Apple Motion › Cinema 4d > Motion problems
  • Cinema 4d > Motion problems
    Posted by Shane Wiersma on June 1, 2011 at 10:23 pm
    I am having some issues with importing a Motion file created by Cinema 4d r12. I have used this work flow many time with AE but I am just getting into Motion so I hope I am overlooking something simple.
    I can get the lights, camera and Nulls in and everything seems great except I have a slight jumping in the camera. The animation on the nulls seems solid but the camera is jerky.
    I though it might be a playback issue but rendering out a file has the same result. I checked the camera path in the keyframe editor for some crazy frames or anything unusual but everything looks fine.
    It is very noticeable on long slow camera moves.
    Any thoughts?
    -Shane
    Kurt Hartman replied 15 years, 3 months ago 3 Members · 4 Replies
  • Andy Neil
    June 2, 2011 at 3:48 pm
    Can you post your project sans media so we can take a look? What format are you working in? Does the frame rate of the C4D camera match the Motion project?
    Andy
    https://www.timesavertutorials.com
  • Shane Wiersma
    June 2, 2011 at 5:42 pm
    Hi Andy, thanks for the help. I was working from an image sequence and yes the frame rates are the same in Cinema & Motion (24 fps). Here is a link to the Motion file with only some text to illustrate the problem.
    https://dl.dropbox.com/u/4742658/JumpyCam.motn.zip
    -Shane
  • Shane Wiersma
    June 9, 2011 at 7:17 pm
    Bump.
    I ended up doing this project in AE but would love to know whats going on with Motion for future projects. Anyone else using Cinema 12 with Motion 4?
  • Kurt Hartman
    June 20, 2011 at 9:37 pm
    I just encountered the same exact problem, slight camera wobble when using the c4d cam in Motion. Would love a solution as I’m trying to make a FCP template with camera animation from Motion (3d camera move on a logo that I’m making a drop area for our editors to swap in new logos).
