Activity › Forums › Maxon Cinema 4D › Cinema 4D (Creating Clovers)
  • Cinema 4D (Creating Clovers)
    Posted by Jeff Clark on October 14, 2009 at 6:11 pm
    Hello all, I’m hoping someone can help me out with this urgent question.
    I created a tunnel that travels underground with grass all around the interior of the walls. However my client is requesting there be random small clovers within the grass. What’s the best way to create these?
    I’d like this to look realistic. I have photo textures if that helps.
    Jeff Clark
    Broadcast Designer
    jeff.clark@nbcuni.com
    Jeff Clark replied 16 years, 11 months ago 3 Members · 6 Replies
  • Adam Trachtenberg
    October 14, 2009 at 6:37 pm
    Do you have MoGraph?
  • Brian Jones
    October 14, 2009 at 8:00 pm
    …or (possibly) Hair but MoGraph would be easier
  • Jeff Clark
    October 14, 2009 at 8:27 pm
    I think I have MoGraph. I’m pretty sure it came with the Cinema 4D bundle we purchased, but I’m not sure how to use it. I’m a pretty quick learner if I have direction though. Think you could help?
    Jeff Clark
    Broadcast Designer | Animator
  • Jeff Clark
    October 15, 2009 at 4:09 pm
    Jeff Clark
  • Brian Jones
    October 16, 2009 at 1:22 am
    You need to make a Cloner and put it in Mode/Object with Up Vector/None and Mode/Surface. MoGraph is really deep, you can do a lot by combining settings so there is no easy way to tell you, you have to do some tutorials and play with it to get a grasp of what it will do. Here’s quick example, the Seed value on the Cloner Object / Object tab is very important, I just scrolled it’s value until I got a distribution of the ‘clovers’ until they did not intersect each other.
  • Jeff Clark
    October 16, 2009 at 5:59 pm
    Thanks for your help. I’ll go ahead and mess around with it.
    Jeff Clark
