Activity Forums Maxon Cinema 4D Cinema 4d color scheme
  • Cinema 4d color scheme
    Posted by Xavier Albarracin on June 23, 2018 at 8:09 am
    I just want to ask, how can I change the color scheme for those two. The background for the slider bar and the input border. I tried to check and change the color for every field but it seems that I can’t find the settings to change each of them. I hope someone can help me with this problem. By the way, I’m using r19. Thank you so much. image below
    Matthew Oneill replied 8 years, 2 months ago 2 Members · 1 Reply
  • Matthew Oneill
    June 29, 2018 at 10:03 am
    You’ll likely find the gadgets are controlled through hand made image files.
    Cinema 4d/resource/modules/c4dplugin/schemes/dark/
    Then you have 3 tiff files you can edit.
    Mash
