Activity Forums Maxon Cinema 4D Cinema 4D clip transparent on Sony Vegas
  • Cinema 4D clip transparent on Sony Vegas
    Posted by Philip Bui on October 13, 2014 at 2:55 am
    Hello all,
    Quick note, this is my first post.
    Anyway, my situation is that I’m making an intro for my channel using a Cinema 4D clip which I planned to transfer on Sony Vegas 12 to continue the edit.
    The problem is simple: When I put the 3D clip from Cinema 4D, it is transparent and everything goes in front of it (It’s not a layering problem from Sony Vegas, I have already edited multiple times with Sony Vegas.)
    For exemple, If I try to put a background to the clip, the background is gonna appear behind the clip but we will see trough it. The opacity is at 100% so I don’t understand what the problem is.
    RSVP and thanks in advance
    James Strecker replied 11 years, 10 months ago 2 Members · 1 Reply
  • James Strecker
    October 14, 2014 at 9:45 pm
    Are you saying the transparency on the C4D clip is not working correctly, like it isn’t actually transparent? If so, you’ll need to right-click and choose Properties, then tell it the correct alpha channel.
    If this isn’t your issue, then I’m sorry but I’ve never come across something quite like that. Good luck.
    James Strecker
    JTS Entertainment
    https://www.youtube.com/JTSEntertainment
