Activity Forums Maxon Cinema 4D Cinema 4D, Amazon EC2 and Team Render
  • Cinema 4D, Amazon EC2 and Team Render
    Posted by Dominic Plaza on February 18, 2014 at 10:16 am
    So I set up Amazon EC2 Cloud Based render server and installed C4D Team Render on it. Everything seems to work fine there. I could find local machine, you can see configuration and green lights, ready to work.
    On the other side I have the problem. After activating Team Render on my main computer and trying to add new machine I get the message “Could not reach remote machine”. I removed firewall on my computer and the problem persists. Running out of ideas and would like to check if someone had the same problem.
    Dominic Plaza replied 12 years, 6 months ago 2 Members · 2 Replies
  • Ian Houser
    March 4, 2014 at 10:41 pm
    Did you get this working? I haven’t set up EC2 and Team Render yet but it sounds like you need to allow incoming communications on your EC2 firewalls. I guess this depends on your IP setup (VPN, or static IP), but it seems like there’s some sort of routing issue on the Amazon side.
  • Dominic Plaza
    March 5, 2014 at 6:17 am
    No I didn’t make it work from my computer. I had to install C4D on the server and run it from there. My computer seems to block outgoing connection and C4D not even trying to connect to the server. I get the message “Could not reach remote machine”. I tried everything such as removing firewall, clean reinstallation of software etc
    Otherwise everything on EC2 works fine and its great and cheap solution for the future renders.
