Activity › Forums › Maxon Cinema 4D › Cinema 4D 11.5 rigid body tag
  • Cinema 4D 11.5 rigid body tag
    Posted by Tyler Bingham on June 9, 2011 at 6:46 pm
    Ok well i’m using Cinema 4D 11.5 and I right click on the object i’m using and scroll down to mographs tag to use the rigid body, but it’s not there can anyone help me?
    Tyler Bingham replied 15 years, 3 months ago 3 Members · 9 Replies
  • 9 Replies
  • Randy Johnson
    June 10, 2011 at 8:09 am
    If you go into the Help tab and look at personalize do you have Mograph 2?
    /Randy
  • Tyler Bingham
    June 11, 2011 at 12:34 am
    I click personalize and it just says i’m using the demo, so I guess that means I can’t use rigid body.
    Tyler
  • Randy Johnson
    June 11, 2011 at 7:09 am
    Why not get the r12 demo so. You can use the full dynamics then.
    Randy
  • Tyler Bingham
    June 11, 2011 at 9:26 pm
    There is no cinema 4d 12 or well I thought there wasn’t.
    Tyler
  • Tyler Bingham
    June 12, 2011 at 3:32 am
    Wait never mind I am using cinema 4D 12 demo and it doesn’t have rigid body on it.
    Tyler
  • Brian Jones
    June 12, 2011 at 4:45 am
    in 12 the Dynamics are in the Simulation menu
  • Tyler Bingham
    June 12, 2011 at 4:51 am
    I know that, but when I use that dynamics way for example I am using a ball and a block of squars when the ball hits the 16X16 block of squares it rolls off but the squares don’t move at all how would I fix it so the block move in every direction like they should?
    Tyler
  • Brian Jones
    June 12, 2011 at 3:35 pm
    it sounds like either you have set the grid of squares (cubes?) set as a Collider – fix it by making them a Rigid body with the Trigger set to On Collision
    or
    you have a Rigid Body on the grid but you have not set Inherit Tag to Apply Tag to Children and Individual Elements to All
  • Tyler Bingham
    June 13, 2011 at 3:03 am
    Thanks your awesome it worked.
    Tyler
